Please help me with my smart component
Maraiica
My robot studio station have a sc_vacuum, it attaches and detaches the item properly when it is not simulated but, when it is in simulation, the sc have no problem attaches to the item but it cannot detaches. i cant find the problem to this, need help..please..
In the past, the same problem occur on one of my rs station and i was needed to install the new version of the robot studio..then my station was perfectly fine..does this have the same problem??..
i am currently using 5.15 Robot studio,is there a newer version of Robot Studio?..Thanks in advance..
I still don't know the problem, or may be there is a bug or my station is corrupt but i build a new station with the same sc_vacuum and there is no problem. Can someone tell me, how to use property binding, please..i am trying to bind the property of a smart component source so that the copy will have the same property, which means that if the source is triggered the copy will triggered as well and vice versa . Please help..
We have done some improvements to the Smart Components in 5.15.01. It is available for download from http://www.abb.com/roboticssoftware. Please download it and see if you get improved results.
ABB1
