Regression in 5.15.01: Jump to target fails for IRB 260, IRB 460. IRB 660 and IRB 760
Unfortunately, a regression was introduced in 5.15.01. When doing Jump to Target axis 4 is set to zero degrees regardless of the true target orientation. The problem appears also for View Robot At Target, and Linear Jog.
However, target creation works as expected, the targets get the correct orientation when teached. Also robot program execution and simulation works fine, then the orientation is correct.
The problem will be fixed in RobotStudio 5.15.01 Service Pack 1 that is planned to be released in June.
We are sorry for the problems caused.
Kind regards,
ABB
ABB
1
The problem has been fixed in RobotStudio 5.15.02 that is available for download.Henrik Berlin
ABB0
