Tilt and Turn External axis for surface coating insustries
sturner
Does anyone have a model of a typical tilt and turn external axis that would get used in a metal spraying industry.
I understand that Independant motion is not fully supported and you have a limited rotation...But A model that partially works would be usefull even if I have to set back to zero manually using the mech jog joint in the station.
Many thanks
- 40 AppStudio
