Robotstudio - Fatal error
When I try to connect an interrupt on a num array I get a fatal error. This error is reproducible on the same way.
Running RS 5.15.01 on Windows 7 64bit
When making this post i get an another error.
  • Hi Jeffrey,
    Sounds like you've encountered a bug!
    Please send a pack&go of your station, including a detailed explanation of how to reprouduce the problem, to your local ABB Robotics representative. If you don't know the name of your local contact please check at www.abb.com/contacts. (Since it seems that you are located in the Netherlands, Ron Nakken or Jan Bronkhorst may be able to help you).
    Please also include your 'machine ID' from the help page, next to the build number of RobotStudio (preferable in text) and a zip file of your support log files. (Use the support tool available in the Windows start menu.)
    Thanks for your time.
    ABB
  • Hi Hendrik,
    Thanks for your answer. I have made an report using the support tool and added a pack&go file. Great tool.
