Modifying Named Points
Greenhorn
Greenhorn
edited June 2013 in RobotStudio
Hello, can someone explain to me how to modify a named point (robtarget) in Robot Studio Online (RSO)? I have been leaving all points as asterisks (*) so I can modify in RSO but this is becoming confusing.  I have tried everything I can think of with no success. Any advice is appreciated.
Thank you in advance.
Post edited by John Wiberg on
  • In RobotStudio Online? In that you'd have to do it manually in the text, and that is no gain.
    However if you use ordinary RobotStudio it is easy.
    Connect to the controller -> Go Offline
    Sync the module to Station
    In the Home tab, in the Paths & Targets browser, select all the inline targets you want changed.
    Right click >> inline
    Sync to VC
    Open up the RAPID editor and save the module...
    Tada, done.
    It works the other way as well.
