Creating Mechanism - Robot
apox
Hi,<div><br></div><div>when creating a mechanism of type robot i specify joint axes but something goes wrong with the rotational axis after compiling the mechanism.</div><div><br></div><div>Preview of axis in mechanism builder (seems to be ok, the last link should rotate around the green axis):</div><div><br></div><img src="https://us.v-cdn.net/5020483/uploads/FileUpload/d4/8d5ec511e3f8c21b4a22867b47ead5.png"><div><br></div><div>Result after compiling the mechanism (rotation is wrong):</div><div><br></div><div><br></div><img src="https://us.v-cdn.net/5020483/uploads/FileUpload/2f/58bafe88c9a94cb76de50d49cbb259.png"><div><br></div><div><br></div><div><br><div><br></div><div><br></div></div>
Set the local origin of all your parts (that become a link in your mechanism) to 0,0,0 / 0,0,0 (equal to graphic origin) and create your mechanism again
regards
regards
Christian0 -
Yes, do not move them from the origin, otherwise they will appear in random locations and your movements will be skewed.
