Rotate a target around its own x
pjneil
I am trying to rotate targets around their own x axis, my understanding is that I need to use Martix4 to do this but I am not sure how to do it. I have all of the required targets and am able to step through them with a foreach loop.
Thanks
Hi pjneil,I have this function that should be able to do what you search for
private static void RotateTarget(RsTarget target,Axis axis, double rotationAngle){Vector3 vAxis = target.Transform.GlobalMatrix.GetAxisVector(axis);//Get the Matrix of targetMatrix4 tMatrix = target.Transform.GlobalMatrix;//Rotate the matrixtMatrix.Rotate(target.Transform.GlobalMatrix.Translation, vAxis, rotationAngle);//Set the new matrix to target matrixtarget.Transform.GlobalMatrix = tMatrix;}Hope it is usefull,Regards LarsLars Glud
Danrob A/S0
