Rapid Editor
i have a question how can i transfer the I/O Signal of my Smart Component to the Rapid Editor
I create a Path, but in the Rapid Editor i cant use the I/O Signal of my Smart component
best regards
  • Hi Dante!
    Only I/O signals in the controller can be accessed from RAPID. Create signals in the controller. Then bind them to your SC using Station Logic. Now you can affect the SC from RAPID.
    Best Regards, Niklas Skoglund
    ABB Robotics
    Developer Center
    RobotStudio Blog
  • hi Niklas
    Thanks for your answer.
    Now i have a connection between my controller and my smart component, but what is the command for a DI.
    I tried it with set, but it doesnt work.
  • You cannot set a input
    If you want this. Create an output and make a crossconnection between from the output to the input
    RobWelding
    The Netherlands
