Wireless Connection
is there a way to connect to an IRC5 controller using a wireless access point or can RSO only us a connection from the ethernet port?
  • Shouldn't be any problem I have used a wireless access point from dlink(can't remember which one at the moment) connected directly to the serviceport.
    Per Svensson
    Consat Engineering
  • do i need to set a static IP address or is it usable with a DHCP network?
  • If you connect to the service port you should be fine with dhcp.
    Per Svensson
    Consat Engineering
  • I use an Asus wl-330gE for that. Small and reliable..
  • Hello Petjo,  could you explain what settings you used on the Asus wifi adapter? Also were there any changes to the settings for the service port?
  • Hi
    I think I set the adapter to bridge mode and setup wifi to replicate the serviceport ip adress. No changes on the robotcontroller
  • Note that the service port is a DHCP server, if you want to use other ports you need the option PC Interface on the robots
    Regards
    Knud Erik Lindberg
    Danrobotics
