Download screen maker
Dear,
I have the license to RobotStudio and screen maker, but in the CD thai i have ther'isent the screen maker where i find it ?
best regard's
Simone
Screenmaker is installed when you install robotstudio, you can find it in the tab "Controller", then choose the icon Flexpendant and under this one you find Screenmaker.
BR
Peter
hello Peter,
the icon it's trasparent and it's impossible click it.
SG
hello,I've got the same problem as well. its impossible to click the sreenmaker icon.0
The problem is that in the 32 bit version it's ok but in the 64 bit version it's not ok0
Hi simonegr and RoboWiz,
When RobotStudio is installed on a 64bit OS it installs both a 32bit and a 64bit version. When starting 64bit RobotStudio you will get a prompt telling you what it doesn't support yet (you can also find this information in the RobotStudio release notes), one of those things being ScreenMaker.
So to use ScreenMaker you need to start the 32bit RobotStudio which is already installed and ready to be used on your PCs.
Start > All Programs > ABB Industrial IT > Robotics IT > RobotStudio 5.xx > RobotStudio 5.xx.yy
John
Developer Center1
- 359 IRC5
- 77 OmniCore
- 851 RAPID Programming
- 29 AppStudio
