Path decleration
Hi, I create about 50 Paths. I Need a decleration, with which i can choose the Paths i Need. I Connect robotstudio with another PC via OPC. The other PC has to choose the Paths he Needs.
  • Hello,
    You can use an string declaration (array) to store the paths you want to execute.
    Then you can use this proccall instruction:
    PERS String path_stored{5}:=("path1","path2","path3","path4","path5");
     PERS String path_execute:="path1";
    %path_execute%;
    So you can change the name of the path by
    path_execute:=path_stored{5};
    You can do it in a loop and when the string is empty the program is ready.
    greetings
  • hi,
    if i wanna change the name. i have to use the decleration  PERS String path_execute:="path1";  %path_execute%;?
    What you mean with a loop ?
  • Here is an example of how you can do it.
    MODULE
    ts
    PERS String path_stored{6}:=["path1","path2","path3","path4","path5",""];
    PROC Main_Rot()
    MoveAbsJ [[0,20,0,0,0,0],[9E+09,0,0,9E+09,9E+09,9E+09]],v200,fine,tool0\WObj:=wobj0;
    FOR i FROM 1 TO 99 DO
    path_execute:=path_stored{i};
    IF path_execute="" GOTO end;
    %path_execute%;
    WaitTime 1;
    ENDFOR
    end:
    PROC Path1()
    MoveAbsJ [[0,0,0,0,0,0],[9E+09,0,0,9E+09,9E+09,9E+09]],v200,fine,tool0\WObj:=wobj0;
    PROC Path2()
    MoveAbsJ [[45,0,0,0,0,0],[9E+09,0,0,9E+09,9E+09,9E+09]],v200,fine,tool0\WObj:=wobj0;
    PROC Path3()
    MoveAbsJ [[90,0,0,0,0,0],[9E+09,0,0,9E+09,9E+09,9E+09]],v200,fine,tool0\WObj:=wobj0;
    PROC Path4()
    MoveAbsJ [[-45,0,0,0,0,0],[9E+09,0,0,9E+09,9E+09,9E+09]],v200,fine,tool0\WObj:=wobj0;
    PROC Path5()
    MoveAbsJ [[-90,0,0,0,0,0],[9E+09,0,0,9E+09,9E+09,9E+09]],v200,fine,tool0\WObj:=wobj0;
    ENDMODULE
    You need an change the executed routine.
    gr
  • hi,
    thanks for the answer.
    I dont understand the decleration after proc main.
    I mean:,,MoveAbsJ [[0,20,0,0,0,0],[9E+09,0,0,9E+09,9E+09,9E+09]],v200,fine,tool0\WObj:=wobj0;'', from where you get this decleration?
