How to add an existing system to an station with an Addin
Good morning,
I would like to know how to add ( sample code if possible) of how to add an existing system to an station with an addin. I do not want to add an existing robot ( of this there are several examples in developercenter)I want to add the complete system with logic.
Thank you very much
Best Answer
As feedback ,this is the solution. However its very strange:myImportedSystem.StartAsync(VirtualControllerRestartMode.WarmStart,myMechanismList );myMechanismList is totally void ! (?¿)public static void ImportSystem(string SystemPath){Station myStation = Project.ActiveProject as Station;RsIrc5Controller myImportedSystem = new RsIrc5Controller(SystemPath);List<Mechanism> myMechanismList=new List<Mechanism>();myStation.Irc5Controllers.Add(myImportedSystem);myImportedSystem.StartAsync(VirtualControllerRestartMode.WarmStart,myMechanismList );}0
Im trying to figure out the same thing, i have built an addin that creates a virtual system and RsIrc5Controller from an excel sheet, I can see that your issue is that your trying to parse an empty mechanism list.... need to find out how to select the mechanism library available here C:\Program Files (x86)\ABB Industrial IT\Robotics IT\RobotStudio 6.06\ABB Library\Robots If you figure it out let me know!0
- 858 RAPID Programming
