Custom Buttons on GTPUMessageBox
ycasas
Hello all,
I would like to show a message box containing buttons with custom text (not OK, Cancel, Yes, No). This is possible with some of the overloaded methods of GTPUMessageBox.Show, but I don't know how to handle the click event of the custom buttons.
Can anyone show me how to do it? Some code snippets, maybe?
Thank you,
Yolanda Casas
Hello again,
Finally I found the way to make it work... I will post some sample code in case it can be of use to anyone else:
GTPUMessageBox.Show(this, new MessageBoxEventHandler(HandleSelectionResult), "Please chose A or B:", "Select option", ABB.Robotics.Tps.Drawing.TpsIcon.Info, new string[] {"A", "B"});
void HandleSelectionResult(object sender, MessageBoxEventArgs e)
if (e.ButtonText.Trim().CompareTo("A") == 0)
// Do stuff corresponding to A
else if (e.ButtonText.Trim().CompareTo("B") == 0)
// Do stuff corresponding to B
*Note the "Trim()" operation on e.ButtonText before the comparation!!
Regards,Yolanda Casas0
