No valid calib data is setup
Hi all,
I'm trying to use a Digi I/P laser camera from ServoRobot and I have it up and running. Its been calibrated and I have afterwards tried to use the OptSearch_1D and ArcSearchLStart, but both returns with the error: 80001 No valid calib data is setup.
I guess there are some naming convention or setting that is not probably since it can't find the calibration results?
All help and suggestions is very welcome.
Regards, Lars
Also, is there any manual describing the two mentioned methods?
Lars Glud
Danrob A/S
Danrob A/S
Hello Lars,
I have same error with another laser tracker (Scansonic) and have failed to recover error. Could you please tell me how did you fix this issue?
Best regards.
Erdem.0
