Virtual Controler fail to start
My virtual controler does not want to start:
RobotStudio .NET exception: Le serveur RPC n’est pas disponible. (Exception from HRESULT: 0x800706BA)
Base exception: COMException
Server stack trace:
at RobotStudio.Services.RobApi.IRobVC.IsRunning(Int32& bRunning)
at RobotStudio.Services.RobApi.RobVcFactory.WaitUntilServerRunning(IRobVC vc)
at RobotStudio.Services.RobApi.RobVcFactory.<>c__DisplayClass2.<StartVC>b__0(TaskCompletionSource`1 tcs, List`1 finals)
at RobotStudio.Services.RobApi.TaskUtils.<>c__DisplayClass1`1.<Run>b__0()
Exception rethrown at [0]:
at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)
at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccess(Task task)
at RobotStudio.Services.Controller.ControllerService.<StartAsync>d__3e.MoveNext()
Exception rethrown at [1]:
at RobotStudio.Services.Controller.ControllerService.<StartAsync>d__34.MoveNext()
Exception rethrown at [2]:
at RobotStudio.Services.Controller.ControllerService.<Start>d__2f.MoveNext()
Exception rethrown at [3]:
at ABBInternal.Controller.StationVirtualControllerManager.<StartLoadedController>d__d.MoveNext()
If this is related to your computer shut down you wrote in your other thread, you may to add the VC to a new station and do an I-Start
Before this you should copy your RAPID moduls under <your VCs name>\INTERNAL\RAPID\PRGx\, if you have RAPID code in the VC that was not saved with a backup or as file
regards
Christian
regards
Christian0
- 858 RAPID Programming
