Problem saving in RS 5.15/01
When trying to save from RS, for example a prog module, directly to a network drive. We get an error.
The error says that there is an access problem. (see attached file).
This is when running RS on Windows 7 X64. (both the 32 bit RS, and the 64 bit give the same problem).
We have another computer running on Win32 (RS 5.15/00). And there it works fine.
The network drive is nothing strange, it's a normal shared folder on the server. No other applications what so ever have any problems accesing it.
Does any one have any idea what might be the problem?
/AU
Post edited by Niklas Skoglund on
Moved to RobotStudio. RobotStudio Online is for the Windows Store apps.0
I think this problem is fixed in RobotStudio 5.60, out now. Get it from http://new.abb.com/products/robotics/robotstudio/downloads
Let us know, if you still get in in 5.60.The reason was that the save module command did not check the credentials in the proper way.
/Henrik
ABB0
