Robot BASE frame more than 1000 mm away from the World frame origin
Hi everyone.
I have a robot installed on a stand 1,3 m above the ground.
I have to keep the world frame origin below the robot base, on the ground.
In the Motion>Robot section of the controller configuration I cannot enter a value greater than 1000 for Z.
How can I solve this issue?
Thanks!
The configuration usualy works in meter not millimeters. I think a value of 1.3 would do wonders for youRobWelding
The Netherlands0
