Write number in Group Output in ieee-754 format ?
I need to write some parameter in a Group Output of 32 bits in the ieee-754 format. Example to write the value 15 i need to write the num 1097859072.
Any help will be appreciated.
Thanks
you can use the instructions PackRawbyte and UnpackRawbyte to convert your value into ieee-754 format or use use the attached function.
Example:
Tpwrite "15 = "\Dnum:=FloatToUInt32(15);FUNC dnum FloatToUInt32(num Value)
VAR rawbytes raw_data;
VAR dnum dnResult;
PackRawBytes Value,raw_data,1\Float4;
UnpackRawBytes raw_data,1,dnResult\IntX:=UDINT;
RETURN dnResult;
endfunc
Regards
Micky
1
