Try, Catch equivalent [moved from RobotStudio]
Patient
Patient
edited October 2013 in Robot Controller
Is there anything in RAPID, equivalent to using try and catch statements in C#?
I am trying to read CSV files but want my program pointer to go back to main when it fails to open a file without resetting the robot or acknowledging any errors.
Post edited by Jonathan Karlsson on
  • Micky
    Micky ✭✭✭
    you can use the error handler inside each routine to handle this problem.
    Example:
    PROC ReadCSV()
      Open "HOME:" \File:= "Mydata.CSV", logfile \Read;
    ERROR
      IF ERRNO = ERR_FILEOPEN THEN
       !Handle the error
       EXIT;
      ENDIF
    Please refer to the RAPID manual for further information.
    Regards
    Micky
