orientation by Rapid
At this moment I am working on a project were I have to send every position to my Computer.
so now i use
VAR robtarget Target.
For i FROM 0 TO 1001 DO
Target.trans.y:=Target.trans.y-0.1;
MoveJ Target, v, z, tool;
Other than the xyz also the orientation has to be changed every run in the For-loop. because the robot has to move sort of circular. I know the algabra for the angles.But i dont konw how to use q1-q4.
anybody help?
greatings from Holland
you can use OrientZYX to calculate the quaternions from angles.
Target.rot := OrientZYX(anglez, angley, anglex)
BR
Peter
Hello Peter,
Thanks, we tried but now we face an another problem. We are simulating a code with some Target 's but those targets are not the same as in real time.
anybody help?
What do you exactly mean by 'those targets are not the same as in real time'?
Benteler Maschinenbau CZ0
- 38 AppStudio
