FlexPendant
Options
Klaus
When i try to test som TPwrite on Flexpendant i open it before starting simulating but as soon i start simulating it close down the Flexpendant then i have to open it again and somm of my txt on the screen is gone
Hope some one can help
Best Regards
Klaus Soenderhegn
www.cadalysator.dk
Klaus Soenderhegn
www.cadalysator.dk
The flexpedant is only closed down when you are running in time sliced mode. The reason for this is that the flexpedant not supports time- sliced mode.Change mode with the menu "tools-options-simulation" and select free run mode instead of time-sliced
You can also investigate the option "tools-options-robotics-flexpedant' and enable the feature "always on top".
- 400 UpFeed
- 20 Tutorials
- 14 RobotApps
- 301 PowerPacs
- 406 RobotStudio S4
- 2.8K Robot Controller
- 345 IRC5
- 73 OmniCore
- 844 RAPID Programming
- 20 AppStudio
- 108 Collaborative Robots
