Where are RS options saved?
When using RobotStudio, you can modify parameters in File/Options, where are those parameters saved?
  • Hi,
    The options are saved in the file
    C:\Users\<user name>\AppData\Local\ABB Industrial IT\Robotics IT\RobotStudio\Options5.15.xml
    The file is saved when the RobotStudio is closed. If you have several instances open, the last one will overwrite the previous changes, if any.
    If you delete the file, it will be recreated with the default options.
    /Henrik
    ABB
