Checking data from serial channel
THOD
Is there a way to see if there is data in the serial buffer and if there is not then continue? I have a While loop where I want to see if another piece of equipment has sent data. If it has not then I want to do some other things.
WHILE TRUE DO
szCMDResult := ReadStr(ReadData\Delim:="-");
TEST szCMDResult
CASE szTest1:
ENDTEST
!Do something else
ENDWHILE
Thanks
So this is what I have come up with. Please tell me if it is stupid and I am just missing something.I basically catch the error of a time out.WHILE TRUE DOszCMDResult := ReadStr(ReadData\Delim:="-"\Time:=2);TEST szCMDResultCASE szTest1:ENDTEST!Do something elseENDWHILE......IF ERRNO = ERR_DEV_MAXTIME THENTRYNEXT;ENDIFAny thoughts?0
