Mesh Rebuild Removes all but 1 mesh in 5.60
I have an addin created in 5.15 32bit which I am loading into 5.60 32bit. I have to set the local origins of my parts using the example given in the Developers center. When I use the Mesh.Rebuild() Method all but 1 of the meshes are removed from the part. In 5.15 this works fine
Post edited by Henrik Berlin on
Best Answer
Hi Simon,
Looks like you've found a bug. Please get in touch with your local ABB Robotics representative and ask them to log a PDD for your problem. It would be helpful if you are able to describe how it can be reproduced. Please also add any relevant data to the report.
Kind regards,
Henrik
ABB5
Moved to DeveloperCenterHenrik Berlin
ABB0
- 364 IRC5
- 82 OmniCore
- 853 RAPID Programming
- 34 AppStudio
