Using RobotStudio 5.60 and 5.15 together
BioTop
Using both versions, I simply wish to inform users that a library saved under 5.60 would NOT be usable in 5.15. The rslib can be loaded but stay invisible in 5.15, which can be very frustrating.
Similarly, a station saved in RS5.60 won't open up back in 5.15, which is something to consider before using the 5.60.
Maybe one day a 5.15 compatibility saving mode ? A least needed for the librairies ?
It's wonderfull, it's wonderfull ....
RobotStudio 5.60 is supposed to do everything that RobotStudio 5.15 does. Is there any reason why you need to continue using RS5.15.02(this is an earnest question, I'm curious to why you still need it)?
