PC interface Problem in Socket Recive block[MOVED]
Problem statement:
I want to Move robot(IRB 2600) to coordinates given by computer via Ethernet using PC interface(Socket messaging).
Work done so far
On computer side :
I made a program in python which sends array of real no (x, y, z coordinates) via Ethernet. I have tested this program on PLC and it works fine.
On robot
I made a program which is at below which connect through PC using service Ethernet port and connects to computer
Problem encounter
- My Program is stuck on the Socket Receive statement.
- Socket receive have only option t receive data,rawbyte and string when I tried to use rawbyte array rd{3} it gives me error
- I can connect to controller to get my program connecting via service port only
My Program
MODULE MainModule
VAR socketdev server_socket;
VAR socketdev client_socket;
VAR socketstatus status;
VAR string client_ip;
VAR rawbytes recive_data;
VAR rawbytes send_data;
VAR rawbytes rd{3};
PROC main ()
connec;
data_transfer;
PROC connec()
SocketCreate server_socket;
SocketBind server_socket,"192.168.125.1",1025;
SocketListen server_socket;
SocketAccept server_socket,client_socket \ClientAddress:=client_ip;
PROC data_transfer()
! My program is stuck at Socket recive statement
SocketReceive client_socket\RawData:=recive_data;
TPWrite recive_data;
SocketSend client_socket\RawData:=send_data;
ENDMODULE
I will really appreciate if you can help me to solve this problem
Thanks
Hi ABB teamfirstly i wish you happy new year !I have sorted problem 1 and 2 ,now i can send and receive string and the pointer is no longer stuck at socket receive command.(the problem was on the pc side)but i am still struggling with problem 2 , Previously i have worked on similar project but the robot was PLC based and i can both send and receive array of real no without any problem.I will appreciate if i can get any light on this subject.Thanks0
Hi Abb Team,currently i am able to successfully transfer coordinates from PC and move my robot accordingly, the only problem is that i am receiving data in bytes so i can't get expected result.please see My code below.i just want your help to sort out how can i receive data in array of num. rawbyte seems an option but i am not able to crack it please help!ThanksMODULE MainModule! this program moves as per data received in bytes.! Problem: coordinates received is in bytes.! solution: data transfer should be done in array of num.VAR socketdev server_socket;VAR socketdev client_socket;VAR socketstatus status;VAR string client_ip;VAR bool keep_listening := TRUE;VAR byte send_array{3};VAR byte recieve_array{3};VAR string xstring;VAR string ystring;VAR string zstring;VAR num xnum;VAR num ynum;VAR num znum;VAR bool xok;VAR bool yok;VAR bool zok;PROC main ()! Move the robot to home position.MoveAbsJ [[0,0,0,0,0,0],[9E+09,9E+09,
9E+09,9E+09,9E+09,9E+09]]\ NoEOffs, v100, z50, tool0; !call connect function to connect to pc.connec;!continus loop for data transfer function.WHILE keep_listening DOdata_transfer;ENDWHILEENDPROCPROC connec()!this function create listen and aceept socketSocketCreate server_socket;SocketBind server_socket,"192.168.125.1",1025; SocketListen server_socket;SocketAccept server_socket,client_socket \ClientAddress:=client_ip;ENDPROCPROC data_transfer()! this function receive the coordinates from PC.! the problem in this function is it can't receive coordinates in Num so i have to:=! convert received byte to string to num.! move robot as per received coordinates.!receive data.SocketReceive client_socket\Data:=recieve_array; !convert byte to string.xstring:=ByteToStr(recieve_array{1}); ystring:=ByteToStr(recieve_array{2}); zstring:=ByteToStr(recieve_array{3}); !convert string to num. the received coordinates are stored in xnum, ynum and znum.xok :=StrToVal(xstring,xnum);yok :=StrToVal(ystring,ynum);zok :=StrToVal(zstring,znum);!display received value on flexpendent screenTPWrite "this is new data recived";TPWrite "x ="\Num:=xnum;TPWrite "y ="\Num:=ynum;TPWrite "z ="\Num:=znum;TPWrite " ";TPWrite ".";TPWrite ".";TPWrite ".";!move robot as per received values.MoveAbsJ [[ xnum,ynum,znum,0,0,0],[9E+09,9E+09,9E+09,9E+09,9E+09,9E+09] ]\NoEOffs, v100, z50, tool0; !sending the received coordinates back to pc for verificationSocketSend client_socket\Data:=recieve_array; ENDPROCENDMODULE0 -
if you want to use rawbytes you have to use the instruction UnpackRawbytes to convert your Bytes into the expected values.
VAR num nFloat;
SocketReceive socket1 \RawData := raw_data_in;UnpackRawBytes raw_data_in, 5, nFloat \Float4;
Please have a look into the reference Manual of the UnpackRawbyte instruction to be able to understand how is works.
regards
Micky
- 40 AppStudio
