Can't use the bending powerpac?
Hi, I just installed RS5.60 (on license) and the Bending PowerPac.
I haven't used PowerPacs before, but I thought I just had to click the 'Add-Ins' tab and find it under the 'PowerPacs' folder on the left, but it is empty.
I tried uninstalling a few times, and also tried installing the machining Power pac, but none of them show up.
What am I doing wrong?
I'm using Windows 7.
/Andreas, Swerob Service AB
I take it that you are installing the 5.60 versions of the PowerPacs.
The PowerPacs also have a trial license which can be found in their corresponding folders, usually under "...../ProgramFiles(x86)/ABB IndustrialIT/RoboticsIT/...."
You might have to install the license first and then restart RS.
Best regards
sudarshan
- 364 IRC5
- 81 OmniCore
- 853 RAPID Programming
- 33 AppStudio
