Communication between two taskt
pacijent
Hello to all, is it possible in multitask system to call routine in normal task from semi-static task routine, and how. Thanks in advance.
By declaring the same variable in both task they will mirror the value.
Task1
pers num a:=10;
Task2
pers num a;
Regards
Knud Erik Lindberg
Danrobotics0 -
no it is not possible to call a routine directly from another task, you can only call routines from the same task.
Regards
Micky
