Rotation around a robot targe.... HELP!!!
Yaserai
Does anybody knows how to palce a holes that exists in a metal plate,one by one, around a robot target?
As I know we can rotat a robot tool with "Oriennzyx" or with "Relttool". But the question is: how to find out the exact x,y,z that should be written to make the write displacement?
Thanks in advance
Thanks in advance
Hi, Yaserai.I am pretty new to RS as well. You could probably try create a new work object with the hole you want and then place the hole where you want it to be, then copy and paste all the targets into your original work object without re-orient it. you can then copy and move the new work object to create multiple holes.Hope it helps.0
Mabey it would be better if you use a fixed tool. And move your product through the tool.RobWelding
The Netherlands0
