IRB6400 in RS5.15.01
Simotion
I know that in the past I was able to insert an IRB6400 in robotstudio
and use the virtual controller to simulate its movenments.
Now I am trying again to insert an IRB6400 but I don't find the model in the catalogue?
Where can I find it?
I am using RS 5.15.01
You can find it in the ABB Library on your hard drive. Use import library in RS and then you will have a direct link to ABB Library. You can also find all robot models on your hard drive under C:\Program Files (x86)\ABB Industrial IT\Robotics IT\RobotStudio 5.60\ABB Library\Robots.
Only the current robot models are shown in the gallery in RobotStudio. Many older robots can only be found on the hard drive.
Hello
Attached is a technote on how to create IRB6400R.
