object reference not set to object instance
hi,
I try to open a station and get this mistake.
stranger mistake: station.rsstn
RobotStudio .NET exception: Der Objektverweis wurde nicht auf eine Objektinstanz festgelegt.
Base exception: NullReferenceException
   bei ABB.Robotics.RobotStudio.Stations.RsPathProcedure.get_ModuleName()
   bei ABB.Robotics.RobotStudio.Stations.RsTask.GetDeclarationUrl(IDeclaration declaration)
   bei ABB.Robotics.RobotStudio.Stations.RsTask.AddToDeclarationsCache(IDeclaration declaration)
   bei ABB.Robotics.RobotStudio.Stations.RsTask.AfterLoad(PimDocument doc)
   bei RobotStudio.API.Persistence.PimDocument.LoadXml(Stream xmlStream, String expectedDocType, Int64 pimStreamSize, Nullable`1 requiredGuid)
   bei RobotStudio.API.Persistence.PimDocument.InternalLoad(String fileName, String docType, Boolean readOnly, Nullable`1 requiredGuid)
   bei RobotStudio.API.Persistence.PimDocument.Load(String fileName, String docType, Boolean readOnly, Boolean allowExisting, Nullable`1 requiredGuid, ProgressNotification progressDelegate, Double progressStart, Double progressEnd)
   bei ABB.Robotics.RobotStudio.Stations.Station.Load(String fileName, Boolean asReadOnly, ProgressNotification progressDelegate, FileNotFoundNotification fileNotFoundDelegate, Boolean loadGeometry)
   bei ABBInternal.FileCommands.FileCommandServices.OpenStation(String fileName, Boolean loadGeometry)
   bei ABBInternal.FileCommands.RecentStationsCommandHandler.LoadRecentStation(String fileName)
   bei RobotStudio.Backstage.BackstageRecent.btn_ExecuteCommand(Object sender, ExecuteCommandEventArgs e)
   bei ABB.Robotics.RobotStudio.Environment.CommandBarButton.RaiseExecuteCommand(ExecuteCommandReason reason)
have anyone an idea, how i can open the station ?
thanks
  • Please get in touch with your local ABB Robotics Service representative that can forward your issue to our tech support. If you don't have an established support contact at ABB you can check at http://www.abb.com/contacts
    ABB
