Two robots on the same track
sturner
Is it possible to simulate 2 robots on the same track?
Hi sturner,
I think you need 2 track mechs in RobotStudio. But the position of the tracks can be in the same position.
Probably you need to fix the jogging direction and external axis zero position on one of the tracks. It depends on the real configuration.
Best regards / Henrik
Kga Offline Center www.kgaofflinecenter.se
Offlineprogramming and simulation in RobotStudio and ArcWeld PowerPac0
- 858 RAPID Programming
