How to set a pause in RS rapid programming
Hi, we are getting a new ABB robot and I am supposed to program to suit our existing welding jigs.
One of the jigs has a two step welding process.
1. put two parts in and  weld.
2. PAUSE, take the welded/unfinished part out, reorient it within the same jig and put more parts in.
3. then finish the weld.
How do I program a pause after the first weld and wait for operators to load parts in for the second step? It's probably going to be press a button type of scenario.
Any suggestions? or how else could this be done with robotstudio?
Any reply would be appreciated.
Kent
Best Answer
  • SjoLi
    SjoLi
    Answer ✓
    You can use a Stop instruction. This stops the robot program untill the play button is pressed again.
    You could also use a MSGbox with an OK Button on the flexpendant. The advantage of this is that you can generate a message on the flexpendant.
    The operator must have acces to the flexpendant for this.
    RobWelding
    The Netherlands
