Code errors
Casius
I need help with this code. I try to check the home position and to set an output if the robot is in home.
VAR wztemporary HomePosition;
PROC TestHome()
VAR shapedata joint_space;
CONST jointtarget home_pos := [[0, -20, 0, 0, 0, 0],[9E+09,9E+09,9E+09,9E+09,9E+09,9E+09]];
CONST jointtarget delta_pos := [[2, 2, 2, 2, 2, 2], [9E+09,9E+09,9E+09,9E+09,9E+09,9E+09]];
WZHomeJointDef \Inside, joint_space, home_pos, delta_pos;
WZDOSet \Temp, HomePosition \Inside, joint_space, O_HomePosition, 1;
The errors are:
"Wrong number of arguments to WZHomeJointDef"
"Wrong number of arguments to WZDOSet"
Thank you!
