Signals connection.
Casius
I need some help please. I have read the documentation and I need a confirmation about how are the signals connected from the gripper to controller. The robot is IRB2600 and single IRC5 controller. I have to use 16 digital I/O.
Do I have to connect the wires signals from sensors to R2.CP or R2CS? And this contacts communicate with R1.CP/CS? and then with XS5?
Which will be the mapping address for in software?
Thank you!
Thank you!
1
As I understand it, both R2.CP and R2.CS are using the same cable, R1CP/CS (a 40-pin, two-cable connector), but each go to a different terminal: R2.CS goes to XP5 and R2.CP goes to XP6.
- 40 AppStudio
