Return an array of num from a function
Hi!
I try to make a function that receive an array of num and then return an array, but i can not get it to work.
Is it possible to return an array from a function??
FUNC num{*} ArrayOrganizer(num Array{*})
! some boring stuff
RETURN Array{*};
ENDFUNC
Best Answer
as i know you can not create a function which returns an array.
But you can create a procedure which returns the modified Array.
Example:
PROC ArrayOrganizer(num Array1{*}, INOUT num Array2{*})
Array2 :=Array1;
endproc
Routine call: ArrayOrganizer arr1,arr2;
arr1 is the original array and arr2 is the modfied array.
/BR
Micky
5
Sad to hear that, but no big problem, will have to try something else
