IRBP created at 180 degrees
Stigsson
Hi Guys
Can someone please shed a bit of light on this issue.
When I create a system from a backup the IRBP unit is created with a 180 degree rotation.
I have tried to change Base frame but get a message the parameter is write only, see attached screen captures.
If I on the other hand import the IRBP unit from ABB library it's OK
Would appreciate some advice and what's the best fix.
Regards
Per Stigsson
