Addin for RS 5.x (VB) problem
Since our add-ins for RS 3.2 were written by VB, we plan to use VB.net as the developement tool. I wrote some codes to imitate the C# code. However, I do not see any add-in in RS 5.0. It would be greatly appreciated if anyone could help me fix the bug.
Imports System
Imports ABB.Robotics.RobotStudio
Imports ABB.Robotics.RobotStudio.Environment
Imports ABB.Robotics.RobotStudio.Stations
Imports System.Windows.Forms
Namespace MyAddinVB
Public Class MyAddinVB
'''<summary>Implements the constructor for the Add-in object. Place your initialization code within this method.</summary>
Public Sub New()
End Sub
' This method is called when RS starts
Public Sub AddinMain()
' Create a new command button
Dim Buttonfiltered= New CommandBarButton("HelloMyAddinVB", "Hello MyAddin VB!")
' Add the button to the "Tools" menu
' The IDs of predefined menus and commands are found in "RobotStudioIDSummary.html"
CommandBarPopup.FromID("MenuTools").Controls.Add(Butto n)
' Connect the command events
' C# Code
'Button.UpdateCommandUI += New UpdateCommandUIEventHandler(button_UpdateCommandUI)
'Button.ExecuteCommand += New ExecuteCommandEventHandler(button_ExecuteCommand)
'VB Code
AddHandler Button.UpdateCommandUI, AddressOf button_UpdateCommandUI
AddHandler Button.ExecuteCommand, AddressOf button_ExecuteCommand
End Sub
Public Sub button_UpdateCommandUI(ByVal sender As Object, ByVal e As UpdateCommandUIEventArgs)
' // Enable the button
e.Enabled = True
End Sub
Public Sub button_ExecuteCommand(ByVal sender As Object, ByVal e As ExecuteCommandEventArgs)
' // Do something
MessageBox.Show("Hello MyAddin VB!")
End Sub
End Class
End Namespace
I got it.
Imports System
Namespace MyAddin
Public Shared Sub AddinMain()
Dim button As CommandBarButton = New CommandBarButton("HelloMyAddinVB", "Hello MyAddinVB!")
CommandBarPopup.FromID("MenuTools").Controls.Add(button)
AddHandler button.UpdateCommandUI, AddressOf button_UpdateCommandUI
AddHandler button.ExecuteCommand, AddressOf button_ExecuteCommand
End Sub
Shared Sub button_UpdateCommandUI(ByVal sender As Object, ByVal e As UpdateCommandUIEventArgs)
e.Enabled = True
End Sub
Shared Sub button_ExecuteCommand(ByVal sender As Object, ByVal e As ExecuteCommandEventArgs)
MessageBox.Show("Hello MyAddinVB!")
End Sub
End Class
End Namespace0
- 88 OmniCore
- 42 AppStudio
