Problem Robotstudio StationViewer / Record to viewer
we are using Robotstudio for several years. After we finished the simulation we use the function Simulation / Record to viewer to generate the *.exe File ( afterwards i get the exe file in which the simulation can be runned by using the Play-Button). It worked well until now.
When i use Robotstudio 5.60 i can create the simulation like in 5.15. But when i start the exe File and run the simulation, the viewer stops after some seconds by an errormessage and i have to close it again. I tried to run the viewer on several computers, but always the same error.
The same simulation worked well in 5.15. I only replaced the robot 6640 by a 6700. So i can not go back to 5.15 anymore.
Is this a bug in 5.60, or ist there a solution?
Thank you for a feedback.
Regards
