Pick and Drop Advice.
Hello, I am new to robot studio so need some help programming a cell, at the moment I have an in-feeder feeing a component into the cell and stopping using a plane sensor, and a robot which runs a path around the component whilst on a pedestal.
What I need help with is how do I pick the part off conveyor with a separate robot place onto the pedestal then remove it from the pedestal when the job is complete?
Thanks
  • Hi, you have better chances getting an answer in the main RobotStudio forum. This is for Controller SDK CTP. I can see that we have lots of posts here which are not about Controller SDK.
    Before I simply help everybody by moving them over, I would like to ask you if there is something in the user interface in the forum application that would make it easier to see the difference between the different forums
    Best Regards, Niklas Skoglund
    ABB Robotics
    Developer Center
    RobotStudio Blog
