Reading data directly from a xls file into a rapid module
Is there a way to get some data from a excel into a rapid module?
I want to make an excel for a palletizing robot to put some data in,for example lenght,width,height,pallet data etc etc,then i want to place this xls file the home directory on the flash,build a standard module that looks to a certain xls file,en take all the data into this module,so i have the same data value's in this module as i have in the xls file.
Maybe a macro that compile's the data in a generated module?
The rest of the program isn't the problem,just get the data from the xls to that module,only when i changing the pattern.
Is there someone with a template or idea's?
Thanks for the help.
BR Roger
