Two robots
smallie1
Hey, I am currently setting up a cell for a project at university and need a part to come down a conveyor stop then be picked up by and placed in a jig, then with a separate robot glue a bead round the edge of the part. I have managed to do both in separate cells but how do i get two robots working in the same cell as if I try to add another at the moment it just appears as a component with no robot controller.
thanks
Hi, you have better chances getting an answer in the main RobotStudio forum. This is for Controller SDK CTP. I can see that we have lots of posts here which are not about Controller SDK.
Before I simply help everybody by moving them over, I would like to ask you if there is something in the user interface in the forum application that would make it easier to see the difference between the different forums
:-*0
