RobotStudio 5.xx with S4
I have found where robotstudio 5.xx can import S4 files, but I haven't found where it can export to the S4 .prg file format.  It retains the modules in individual module files rather than putting them all back into one large .prg file, which is great for editing and loading one module at a time, but is not so good to load up the entire program consisting of large numbers of modules.  Is there a way to have RobotStudio 5.xx create the .prg file?
If anyone else has this issue, I wrote a real easy utility to do this since I couldn't find it in RobotStudio, let me know and I'll get it to you.
  • Hi! I experience the same problem. Can u tell me / get me information about how you did it? It would be very much appreciated! :) thank you.
  • Hey i'm also facing same problem !
    Can you please help me to import S4 files(.prg) into Robot Studio 5.XX/OR Robot Studio 2019.
    It would me very much appreciated !!!!!
    Thanks
  • lemster68
    lemster68 ✭✭✭
    You cannot, load them module by module.
    Lee Justice
