Simulation running at ridiculous speed
kentz
Hi, the simulation in RobotStudio somehow turned to be running at a ridiculous speed. Any idea why is that?
These are my settings for options.
Any idea guys?
Thanks
Hi, John.John Wiberg said:It should be the Free Run setting.
Time Slice is the default setting.
It is free run thats ticked.0 -
I have managed to get rid of the problem by installing the latest version of RS.Reinstall RS = A fix to everything.0
It is the Free Run that causes the problem. You need to be in Time Slice to fix.
BR
Thanks for reply. I have tried everything before re-installing, I guess it is just a set up thing for this particular machine.james.r.proulx said:It is the Free Run that causes the problem. You need to be in Time Slice to fix.
BR
