Bug in SmartComponent PoseMover ?
apox
when using PoseMover SC, I get errors when compiling the SC using LibraryCompiler. The following (simplified) use case demonstrates the steps:
The predefined poses are fine in XML but it seems that it is not possible to restore them.
I attached the exported SC (RSXML) which i am trying to recompile.
Any help would be appreciated,
ASC.
- Create a simple mechanism (Device) and add some predefined poses
- Create empty SC, add (Drag) the mechanism into the SC
- Add PoseMover SC to SC and set properties: select mechanism and one of defined poses
- Export SC as RSXML
- Use LibraryCompiler to compile the exported RS
- Result:
ASC.
