Value of external axis position not updated when Modify External Axis
Just updated to RS 5.61. right click target and go modify external axis. The current external value is not showing what current position is, but rather the position that I have jogged to before.
Anyone else having the same problem?
  • This happens to simulation as well apparently. I have changed the external axis value in rapid program, applied the change. But the simulation is still showing the old external axis value.
    Is this another set up problem?
  • Hi,
    We are not aware of the problem you are describing and I am not able to reproduce it. Please contact your local ABB Robotics service representative (see http://www.abb.com/contacts) that can forward your issue to the RobotStudio support team. Add a pack&go file, and a description of your problem. If you have the time to record a movie with the "Record Application" function (mp4 format) that would be very helpful.
    Kind regards,
    Henrik
    ABB
