about a exception "System.TypeInitializationException" when using PC SDK
Tyler
Tyler
edited May 2014 in Developer Tools
I have referenced this two .dll files (ABB.Robotics.dll and ABB.Robotics.Controllers.dll). I created a button and added a click event. In the click event function, I write one line code " NetworkScanner ns = new NetworkScanner();" Also I have added the using instruction
using ABB.Robotics;
using ABB.Robotics.Controllers;
using ABB.Robotics.Controllers.Discovery;
using ABB.Robotics.Controllers.RapidDomain;
But when I run this instruction, the exception has came out
An unhandled exception of type 'System.TypeInitializationException' occurred in ABB.Robotics.Controllers.dll
Additional information: The type initializer for 'ABB.Robotics.Controllers.Internal.NetworkScanner' threw an exception.
Thank you very much.
Best Answer
    using ABB.Robotics;
    Hello,Tyler. your problem has been solved? I use the 6.03 version of the dll, also encountered the same problem has not resolved, can share with your experience, thank you very much.
