Screenmaker possibilities
Hi all,
I have a few questions about the possibilities with Screenmaker.
I want to develop a general application that controls the robot.
The operator should be able to select a program, for example apply kit to PCB's.
This program should run until the operator interrupts.
When the operator interrupts, the program should stop and another program could be loaded by the operator.
In screenmaker I can call a routine, set an output signal, open a window etc, but is it possible to create a 'Load program' button?
Like the one you have in the production window.
Another question, is it possible to create some password protected screens in Screenmaker?
Most of the screens should be available for the operators, however some settings an operator should not be able to change.
Thanks,
Jeroen Graafmans
