I can't create a System from Layout in RS 5.60
Options
Hello Everyone!
When i try to create it appear a message saying that the mechanism model is unknown and the library model must be manually mapped. What i get to do to solve this problem?
Could someone help me if knows?
I thank yall since now.
Hi rurouniken,
You need to at least tell us which libraries you are using in the layout which fails. Preferably with a screenshot of the Layout browser. Without that info it would be very difficult to answer you with any certainty.
But the generic answer is that there is a generation shift between RobotWare 5.15.x and RobotWare 5.6x and the two generations don't necessarily overlap. So dependent on which library you use you might also need a RobotWare from the 5.15.x generation installed.
The second generic answer would be to upgrade to 5.61.=John
John
Developer Center0 -
I encoutered the same problem, I can't created the system with track.0
- 400 UpFeed
- 20 Tutorials
- 14 RobotApps
- 301 PowerPacs
- 406 RobotStudio S4
- 2.8K Robot Controller
- 348 IRC5
- 74 OmniCore
- 847 RAPID Programming
- 21 AppStudio
- 109 Collaborative Robots
