my robotstudio rapid program doesn't work pro pertly on the robot
F_Batrek
i am a beginner in robotstudio and i have made a rapid program by robotstudio but it doesn't work on the robot, it moves in a different way than i made in the robotstudio...i don't know what i miss?!
we had made a calibration to our robot..& i don't know if i have to made the same with the robot studio & how, or there is a different way to solve it ?
Thanks in advance.
Try to check the coordination of the used workobject, there might be a difference offline --> online
i can't fixed it till now, i tried the same values for the work object which i found on the flex pendant, and tried a seveal different value, but none even close..i added the system parameters files and calibration data from the system backup, and put the same tool data and work object values as well but i got a diffrenet axis movement than i made on robotstudio..!! i am so confused!0
- 84 OmniCore
- 37 AppStudio
